주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo DSi XL Power Board Replacement
필요한 것
  1. Nintendo DSi XL Power Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DSi XL Power Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    댓글 쓰기
  2. Nintendo DSi XL Power Board Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery from the DSi XL.
    댓글 쓰기
  3. Nintendo DSi XL Power Board Replacement, Lower Case: 3 단계, 이미지 3개 중 1개 Nintendo DSi XL Power Board Replacement, Lower Case: 3 단계, 이미지 3개 중 2개 Nintendo DSi XL Power Board Replacement, Lower Case: 3 단계, 이미지 3개 중 3개
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    댓글 쓰기
  4. Nintendo DSi XL Power Board Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
    댓글 쓰기
  5. Nintendo DSi XL Power Board Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DSi XL Power Board Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DSi XL Power Board Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    댓글 쓰기
  6. Nintendo DSi XL Power Board Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi XL Power Board Replacement: 6 단계, 이미지 2개 중 2개
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
    댓글 쓰기
  7. Nintendo DSi XL Power Board Replacement: 7 단계, 이미지 2개 중 1개 Nintendo DSi XL Power Board Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    댓글 쓰기
  8. Nintendo DSi XL Power Board Replacement, Power Board: 8 단계, 이미지 2개 중 1개 Nintendo DSi XL Power Board Replacement, Power Board: 8 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
    댓글 쓰기
  9. Nintendo DSi XL Power Board Replacement: 9 단계, 이미지 1개 중 1개
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
    댓글 쓰기
  10. Nintendo DSi XL Power Board Replacement: 10 단계, 이미지 2개 중 1개 Nintendo DSi XL Power Board Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
132,207 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,617개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 29
지난 30일: 154
전체 시간: 19,366
