주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Entertainment System Controller Cable Replacement
필요한 것
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 1개 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
    댓글 쓰기
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: 2 단계, 이미지 1개 중 1개
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
    댓글 쓰기
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: 3 단계, 이미지 1개 중 1개
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
themap504
회원 가입일: 01/08/15
80 평판
안내서 1개를 작성함
2가이드 댓글
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - 답글 공유
Check for continuity from the pins on the plug side with the wires and soldier them in the corresponding spot, i:e if red is power then you soldier it to the power slot on the motherboard and so on. Check if you can find a instruction book on the controller.
Cgull - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 80
전체 시간: 3,106
