주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo GameCube Front and Back Panel Replacement
필요한 것
  1. Nintendo GameCube Front and Back Panel Replacement, Top Case: 1 단계, 이미지 3개 중 1개 Nintendo GameCube Front and Back Panel Replacement, Top Case: 1 단계, 이미지 3개 중 2개 Nintendo GameCube Front and Back Panel Replacement, Top Case: 1 단계, 이미지 3개 중 3개
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    댓글 쓰기
  2. Nintendo GameCube Front and Back Panel Replacement: 2 단계, 이미지 3개 중 1개 Nintendo GameCube Front and Back Panel Replacement: 2 단계, 이미지 3개 중 2개 Nintendo GameCube Front and Back Panel Replacement: 2 단계, 이미지 3개 중 3개
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    댓글 쓰기
  3. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: 3 단계, 이미지 1개 중 1개
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
    댓글 쓰기
  4. Nintendo GameCube Front and Back Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    댓글 쓰기
  5. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: 5 단계, 이미지 2개 중 1개 Nintendo GameCube Front and Back Panel Replacement, Separate the casing: 5 단계, 이미지 2개 중 2개
    • This step may not be necessary depending on your end goal
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
24다른 기여자 명과 함께
dcarlin
회원 가입일: 11/05/09
399 평판
안내서 4개를 작성함
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 회원
CPSU-MANESS-F09S6G2
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 24
지난 30일: 135
전체 시간: 19,085
