주요 콘텐츠로 건너뛰기
Nintendo Switch 2 Fan Replacement
필요한 것
  1. Nintendo Switch 2 Fan Replacement, Power off the console: 1 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Power off the console: 1 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Power off the console: 1 단계, 이미지 3개 중 3개
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Fan Replacement, Remove the bottom screws: 2 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the bottom screws: 2 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Fan Replacement, Remove the top screw: 3 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the top screw: 3 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Fan Replacement, Heat the right side sticker: 4 단계, 이미지 1개 중 1개
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: 5 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: 5 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: 5 단계, 이미지 3개 중 3개
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Fan Replacement: 6 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 6 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Jimmy
    $7.16
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Fan Replacement, Heat the right side sticker: 7 단계, 이미지 1개 중 1개
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Fan Replacement, Remove the right side sticker: 8 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the right side sticker: 8 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Remove the right side sticker: 8 단계, 이미지 3개 중 3개
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Fan Replacement, Remove the left side sticker: 9 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the left side sticker: 9 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Remove the left side sticker: 9 단계, 이미지 3개 중 3개
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Fan Replacement, Remove the side screws: 10 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the side screws: 10 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Fan Replacement, Open the kickstand: 11 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Open the kickstand: 11 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Open the kickstand: 11 단계, 이미지 3개 중 3개
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Fan Replacement, Remove the back-side screws: 12 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the back-side screws: 12 단계, 이미지 2개 중 2개
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Fan Replacement, Insert an opening pick: 13 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Insert an opening pick: 13 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Fan Replacement: 14 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Fan Replacement, Insert a second opening pick: 15 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Insert a second opening pick: 15 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Insert a second opening pick: 15 단계, 이미지 3개 중 3개
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Fan Replacement: 16 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Fan Replacement, Remove the back cover: 17 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the back cover: 17 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Remove the back cover: 17 단계, 이미지 3개 중 3개
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Fan Replacement: 18 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 18 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 18 단계, 이미지 3개 중 3개
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Fan Replacement, Remove the lower antenna screws: 19 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the lower antenna screws: 19 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
  20. Nintendo Switch 2 Fan Replacement, Remove the lower antenna: 20 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the lower antenna: 20 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to remove the lower antenna.
  21. Nintendo Switch 2 Fan Replacement, Remove the upper antenna screws: 21 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the upper antenna screws: 21 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
  22. Nintendo Switch 2 Fan Replacement, Remove the upper antenna: 22 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the upper antenna: 22 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to remove the upper antenna.
  23. Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: 23 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: 23 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: 23 단계, 이미지 3개 중 3개
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
  24. Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: 24 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: 24 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: 24 단계, 이미지 3개 중 3개
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
  25. Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: 25 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: 25 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: 25 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
  26. Nintendo Switch 2 Fan Replacement, Remove the shield plate screws: 26 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the shield plate screws: 26 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
  27. Nintendo Switch 2 Fan Replacement, Lift the shield plate: 27 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Lift the shield plate: 27 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Lift the shield plate: 27 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
  28. Nintendo Switch 2 Fan Replacement: 28 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 28 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 28 단계, 이미지 3개 중 3개
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
  29. Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: 29 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: 29 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: 29 단계, 이미지 3개 중 3개
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
  30. Nintendo Switch 2 Fan Replacement: 30 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 30 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 30 단계, 이미지 3개 중 3개
    • Unroute the gray antenna cable from its channel along the right edge of the console.
  31. Nintendo Switch 2 Fan Replacement: 31 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 31 단계, 이미지 2개 중 2개
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
  32. Nintendo Switch 2 Fan Replacement, Remove the shield plate: 32 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the shield plate: 32 단계, 이미지 2개 중 2개
    • Pick up and remove the shield plate.
  33. Nintendo Switch 2 Fan Replacement, Disconnect the battery: 33 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Disconnect the battery: 33 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
  34. Nintendo Switch 2 Fan Replacement, Clean the heat pipe: 34 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Clean the heat pipe: 34 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Clean the heat pipe: 34 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Arctic Silver ArctiClean
    $9.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
  35. Nintendo Switch 2 Fan Replacement, Remove the heat sink screws: 35 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the heat sink screws: 35 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the four 3.4 mm‑long silver screws securing the heat sink.
  36. Nintendo Switch 2 Fan Replacement, Free the heat sink: 36 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Free the heat sink: 36 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Free the heat sink: 36 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the heat sink and the processor's heat spreader.
    • Twist the spudger to lift the heat sink and separate the thermal paste bonded to it.
  37. Nintendo Switch 2 Fan Replacement, Remove the heat sink: 37 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the heat sink: 37 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Remove the heat sink: 37 단계, 이미지 3개 중 3개
    • Lift the heat sink slowly to avoid bending its thin copper heat pipe.
    • Slowly lift the heat sink from the front, until the aluminum fin stack at the back is detached from the adhesive beneath it.
    • Remove the heat sink.
  38. Nintendo Switch 2 Fan Replacement, Clean the thermal paste: 38 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Clean the thermal paste: 38 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Clean the thermal paste: 38 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $9.99
    • Use high-concentration (90% or higher) isopropyl alcohol or thermal material remover to soak the thermal paste on the processor's heat spreader for one minute.
    • Use a lint-free cloth or cotton swabs to wipe away the thermal paste.
    • Repeat this process until the processor's heat spreader is clean.
  39. Nintendo Switch 2 Fan Replacement: 39 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 39 단계, 이미지 2개 중 2개
    • If you're replacing your heat sink, skip this step.
    • Repeat this process to clean the thermal paste off the bottom of the heat sink.
  40. Nintendo Switch 2 Fan Replacement, Disconnect the fan: 40 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Disconnect the fan: 40 단계, 이미지 2개 중 2개
    • Use the point of a spudger to flip up the locking flap on the fan cable ZIF connector, located next to the fan on the console's board.
  41. Nintendo Switch 2 Fan Replacement: 41 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 41 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 41 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • If you're using tweezers, pull the cable out by its "wings" instead of gripping the cable itself.
  42. Nintendo Switch 2 Fan Replacement, Remove the fan screws: 42 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the fan screws: 42 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the three 5.2 mm‑long silver screws securing the fan.
  43. Nintendo Switch 2 Fan Replacement, Remove the fan: 43 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Remove the fan: 43 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Remove the fan: 43 단계, 이미지 3개 중 3개
    • Slide the fan out of its recess to free its cable, then pick it up to remove it.
  44. Nintendo Switch 2 Fan Replacement, Disassembly complete: 44 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  45. Nintendo Switch 2 Fan Replacement, Install the fan: 45 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the fan: 45 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the fan: 45 단계, 이미지 3개 중 3개
    • Slide the fan into its recess. Ensure its cable slides underneath the edge of the board.
    • Align the fan with its screw posts on the frame.
  46. Nintendo Switch 2 Fan Replacement: 46 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 46 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the three 5.2 mm‑long silver screws securing the fan.
  47. Nintendo Switch 2 Fan Replacement, Connect the fan: 47 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Connect the fan: 47 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Connect the fan: 47 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to slide the fan cable into its ZIF connector until it's fully seated.
    • If you're using tweezers, you can use a spudger to help guide the cable into its connector.
    • Flip the hinged locking flap down to secure the cable.
  48. Nintendo Switch 2 Fan Replacement, Install thermal paste: 48 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install thermal paste: 48 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install thermal paste: 48 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Thermal Paste
    $9.95
    • Apply a bead of new thermal paste to the center of the processor's copper heat spreader, roughly the size of a pea.
  49. Nintendo Switch 2 Fan Replacement, Install the heat sink: 49 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the heat sink: 49 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the heat sink: 49 단계, 이미지 3개 중 3개
    • Set the heat sink's aluminum fins into its recess behind the fan, then lower the heat sink onto the board.
  50. Nintendo Switch 2 Fan Replacement: 50 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 50 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to partially install the four 3.4 mm‑long silver screws securing the heat sink.
    • Tighten the screws in an X pattern. For example: bottom left, top right, bottom right, then top left.
  51. Nintendo Switch 2 Fan Replacement, Connect the battery: 51 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Connect the battery: 51 단계, 이미지 2개 중 2개
    • Align the battery connector over its socket on the board.
    • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
  52. Nintendo Switch 2 Fan Replacement, Apply thermal putty: 52 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Apply thermal putty: 52 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Apply thermal putty: 52 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
  53. Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: 53 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: 53 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: 53 단계, 이미지 3개 중 3개
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
  54. Nintendo Switch 2 Fan Replacement, Lower the shield plate: 54 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Lower the shield plate: 54 단계, 이미지 2개 중 2개
    • Lower the shield plate into place and align it with its screw holes.
  55. Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: 55 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: 55 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: 55 단계, 이미지 3개 중 3개
    • Route the gray antenna cable down its channel on the right edge of the frame.
  56. Nintendo Switch 2 Fan Replacement: 56 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 56 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 56 단계, 이미지 3개 중 3개
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
  57. Nintendo Switch 2 Fan Replacement, Install the shield plate screws: 57 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Install the shield plate screws: 57 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
  58. Nintendo Switch 2 Fan Replacement, Connect the MicroSD connector: 58 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Connect the MicroSD connector: 58 단계, 이미지 2개 중 2개
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  59. Nintendo Switch 2 Fan Replacement, Connect the antenna cables: 59 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Connect the antenna cables: 59 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Connect the antenna cables: 59 단계, 이미지 3개 중 3개
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
  60. Nintendo Switch 2 Fan Replacement, Install the upper antenna: 60 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the upper antenna: 60 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the upper antenna: 60 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
  61. Nintendo Switch 2 Fan Replacement, Install the lower antenna: 61 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the lower antenna: 61 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the lower antenna: 61 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
  62. Nintendo Switch 2 Fan Replacement, Prepare the back cover: 62 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Prepare the back cover: 62 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Prepare the back cover: 62 단계, 이미지 3개 중 3개
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  63. Nintendo Switch 2 Fan Replacement, Install the back cover: 63 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the back cover: 63 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the back cover: 63 단계, 이미지 3개 중 3개
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  64. Nintendo Switch 2 Fan Replacement: 64 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement: 64 단계, 이미지 2개 중 2개
    • Squeeze the rest of the back cover and console together to fasten the clips.
  65. Nintendo Switch 2 Fan Replacement, Install the back-side screws: 65 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the back-side screws: 65 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the back-side screws: 65 단계, 이미지 3개 중 3개
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  66. Nintendo Switch 2 Fan Replacement, Install the side screws: 66 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Install the side screws: 66 단계, 이미지 2개 중 2개
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  67. Nintendo Switch 2 Fan Replacement, Test the console: 67 단계, 이미지 2개 중 1개 Nintendo Switch 2 Fan Replacement, Test the console: 67 단계, 이미지 2개 중 2개
    • Power on the console and test functionality to ensure it's working as expected.
  68. Nintendo Switch 2 Fan Replacement, Install the stickers: 68 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement, Install the stickers: 68 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement, Install the stickers: 68 단계, 이미지 3개 중 3개
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  69. Nintendo Switch 2 Fan Replacement: 69 단계, 이미지 3개 중 1개 Nintendo Switch 2 Fan Replacement: 69 단계, 이미지 3개 중 2개 Nintendo Switch 2 Fan Replacement: 69 단계, 이미지 3개 중 3개
    • Repeat this procedure to install the left side sticker.
결론
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
회원 가입일: 03/24/24
36,897 평판
안내서 224개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 100
전체 시간: 383
