주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
필요한 것
  1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: 1 단계, 이미지 2개 중 2개
    • Pull down on the battery cover release lever and pull back to remove the cover.
    댓글 쓰기
  2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove both batteries from the device.
    댓글 쓰기
  3. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: 3 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: 3 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    댓글 쓰기
  4. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 4 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    댓글 쓰기
  5. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 5 단계, 이미지 3개 중 1개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 5 단계, 이미지 3개 중 2개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    댓글 쓰기
  6. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers remove the three grey button pads from the motherboard.
    댓글 쓰기
  7. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 7 단계, 이미지 1개 중 1개
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
    댓글 쓰기
  8. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: 8 단계, 이미지 1개 중 1개
    • Turn the motherboard over so the channel wheel is facing up.
    댓글 쓰기
  9. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 9 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 9 단계, 이미지 2개 중 2개
    • Pinch the wheel and pull it away from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Travis Taylor
회원 가입일: 04/12/13
539 평판
안내서 5개를 작성함
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G40
4 회원들
안내서 37개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 45
전체 시간: 2,746
