이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you the steps on installing the shoulder buttons. This will be helpful if the shoulder buttons are not working properly.
Only replace the faulty shoulder button(s).
필요한 것
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
