주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Remote B Trigger Button Replacement
필요한 것
  1. Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 2개
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    댓글 쓰기
  2. Nintendo Wii Remote B Trigger Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    댓글 쓰기
  3. Nintendo Wii Remote B Trigger Button Replacement: 3 단계, 이미지 1개 중 1개
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    댓글 쓰기
  4. Nintendo Wii Remote B Trigger Button Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 4 단계, 이미지 2개 중 2개
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    댓글 쓰기
  5. Nintendo Wii Remote B Trigger Button Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    댓글 쓰기
  6. Nintendo Wii Remote B Trigger Button Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 6 단계, 이미지 2개 중 2개
    • Grasp the edges of the motherboard and pull it straight away from the case.
    댓글 쓰기
  7. Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: 7 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: 7 단계, 이미지 2개 중 2개
    • Locate the black sensor screen found at the bottom end of the Wii remote.
    • Grip the free edge of the black sensor screen and gently pull it down to remove from the Wii control.
    댓글 쓰기
  8. Nintendo Wii Remote B Trigger Button Replacement: 8 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 8 단계, 이미지 2개 중 2개
    • Find the two small tabs near the front end of the white plastic housing.
    • Place the flat end of the spudger tool under one tab and lightly push up until the tabs pop out of place.
    댓글 쓰기
  9. Nintendo Wii Remote B Trigger Button Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the remote over and the plastic B trigger will fall out.
    • Catch the plastic trigger so it does not get lost.
    댓글 쓰기
  10. Nintendo Wii Remote B Trigger Button Replacement: 10 단계, 이미지 3개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 10 단계, 이미지 3개 중 2개 Nintendo Wii Remote B Trigger Button Replacement: 10 단계, 이미지 3개 중 3개
    • Flip the motherboard so that the rumble motor and the white plastic housing face up.
    • Place the flat end of the spudger tool under the round rumble motor and lightly push up.
    • Tilt the motherboard to the left and the rumble motor will fall out of the white housing.
    • Do not pull the rumble motor out, this could cause the wires to rip from the motherboard.
    댓글 쓰기
  11. Nintendo Wii Remote B Trigger Button Replacement: 11 단계, 이미지 3개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 11 단계, 이미지 3개 중 2개 Nintendo Wii Remote B Trigger Button Replacement: 11 단계, 이미지 3개 중 3개
    • Flip the motherboard over and locate the two white tabs at the top the plastic housing.
    • Place both thumbs on the inside of the tabs and push the tabs outward.
    • Use the inner sides of your thumbs to separate the motherboard from the plastic housing.
    댓글 쓰기
  12. Nintendo Wii Remote B Trigger Button Replacement: 12 단계, 이미지 2개 중 1개 Nintendo Wii Remote B Trigger Button Replacement: 12 단계, 이미지 2개 중 2개
    • Gently push the rubber button out of the plastic housing.
    • The rubber button is bouncy, so be cautious after pushing it out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Emily
회원 가입일: 04/14/13
2,015 평판
안내서 6개를 작성함
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 32
지난 30일: 214
전체 시간: 20,582
