주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Remote Main Buttons Replacement
필요한 것
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 2개
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    댓글 쓰기
  2. Nintendo Wii Remote Main Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    댓글 쓰기
  3. Nintendo Wii Remote Main Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    댓글 쓰기
  4. Nintendo Wii Remote Main Buttons Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    댓글 쓰기
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 5 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 5 단계, 이미지 2개 중 2개
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    댓글 쓰기
  6. Nintendo Wii Remote Main Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Emily
회원 가입일: 04/14/13
2,015 평판
안내서 6개를 작성함
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 29개를 작성함
5가이드 댓글
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - 답글 공유
Me too, can’t find them.
Michael Velten - 답글 공유
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - 답글 공유
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - 답글 공유
Yo tampoco los encuentro por ninguna parte
kinoto taller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 76
지난 30일: 335
전체 시간: 49,355
