주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Remote Motherboard Replacement
필요한 것
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 1개 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 2개
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    댓글 쓰기
  2. Nintendo Wii Remote Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    댓글 쓰기
  3. Nintendo Wii Remote Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    댓글 쓰기
  4. Nintendo Wii Remote Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii Remote Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    댓글 쓰기
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Nintendo Wii Remote Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    댓글 쓰기
  6. Nintendo Wii Remote Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Wii Remote Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Grasp the edges of the motherboard and pull it straight away from the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Emily
회원 가입일: 04/14/13
2,015 평판
안내서 6개를 작성함
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 29개를 작성함
7가이드 댓글
Where do you find a motherboard and how much do they typically cost?
Jeff - 답글 공유
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - 답글 공유
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign - 답글 공유
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - 답글 공유
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 88
지난 30일: 384
전체 시간: 40,326
