주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Remote Sensor Screen Replacement
필요한 것
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 1개 Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 2개
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    댓글 쓰기
  2. Nintendo Wii Remote Sensor Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    댓글 쓰기
  3. Nintendo Wii Remote Sensor Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    댓글 쓰기
  4. Nintendo Wii Remote Sensor Screen Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii Remote Sensor Screen Replacement: 4 단계, 이미지 2개 중 2개
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    댓글 쓰기
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 5 단계, 이미지 3개 중 1개 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 5 단계, 이미지 3개 중 2개 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 5 단계, 이미지 3개 중 3개
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Emily
회원 가입일: 04/14/13
2,015 평판
안내서 6개를 작성함
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 29개를 작성함
2가이드 댓글
Where can the screen be purchased??
cutsiepie6480 - 답글 공유
how is this moderate difficulty
Sqwerks - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 77
지난 30일: 302
전체 시간: 27,552
