주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii U DVD Drive Replacement
필요한 것
  1. Nintendo Wii U DVD Drive Replacement, Console Outer Case: 1 단계, 이미지 1개 중 1개
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
    댓글 쓰기
  2. Nintendo Wii U DVD Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
    댓글 쓰기
  3. Nintendo Wii U DVD Drive Replacement: 3 단계, 이미지 2개 중 1개 Nintendo Wii U DVD Drive Replacement: 3 단계, 이미지 2개 중 2개
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
    댓글 쓰기
  4. Nintendo Wii U DVD Drive Replacement: 4 단계, 이미지 1개 중 1개
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
    댓글 쓰기
  5. Nintendo Wii U DVD Drive Replacement: 5 단계, 이미지 3개 중 1개 Nintendo Wii U DVD Drive Replacement: 5 단계, 이미지 3개 중 2개 Nintendo Wii U DVD Drive Replacement: 5 단계, 이미지 3개 중 3개
    • On the back of the console, lift up and release the main top cover.
    댓글 쓰기
  6. Nintendo Wii U DVD Drive Replacement, Front Faceplate: 6 단계, 이미지 2개 중 1개 Nintendo Wii U DVD Drive Replacement, Front Faceplate: 6 단계, 이미지 2개 중 2개
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
    댓글 쓰기
  7. Nintendo Wii U DVD Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
    댓글 쓰기
  8. Nintendo Wii U DVD Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the front faceplate.
    댓글 쓰기
  9. Nintendo Wii U DVD Drive Replacement, DVD Drive: 9 단계, 이미지 1개 중 1개
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
    댓글 쓰기
  10. Nintendo Wii U DVD Drive Replacement: 10 단계, 이미지 2개 중 1개 Nintendo Wii U DVD Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Rotate the device so that the disc drive slot is visible.
    • A ribbon cable is attached to the bottom right side of the disc drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the disc drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
    댓글 쓰기
  11. Nintendo Wii U DVD Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the disc drive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 61명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Kim Arre
회원 가입일: 01/11/13
5,730 평판
안내서 8개를 작성함
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 41개를 작성함
49가이드 댓글
I've done with twice with two different drives ordered on Ebay, and keep getting the same error code (160-1402). Is the place I'm buying from selling bad drives, or is there something else that needs to be done after? It goes back to working when I put my old one back in, so I know I'm physically doing it correctly.
Brad Senatore - 답글 공유
Update : For anybody else having this problem, you have to change out the logic board from your old drive to the new one. Pain in the neck, but works!
What do you mean by change out the logic board?
gingindua - 답글 공유
the logic board is inside the disk drive. Remove it and replace it into the new disk drive. This is the same on the Xbox and Playstation
rehrnsberger - 답글 공유
Did an update it failed rebooted and now get a 160-1402. With the DVD drive cover off the Spindle isnt moving. Suspect Drive would seem 160-XXXX is DVD Drive related Errors
Ben Uwins - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 89
지난 30일: 431
전체 시간: 93,846
