주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Node Swap
필요한 것
  1. Node Swap, Loosen front tapcon: 1 단계, 이미지 2개 중 1개 Node Swap, Loosen front tapcon: 1 단계, 이미지 2개 중 2개
    • the standard concrete drilled node
    • If your node is clamped or pole mounted skip to step 3
    댓글 쓰기
  2. Node Swap, loosen back tapcon and swivel node toward you: 2 단계, 이미지 1개 중 1개
    • with the front tapcon removed you should be able to swing the node back toward the concrete surface it's mounted on
    • you'll likely need to loosen the back tapcon and pull up on the cantilever for the node to pivot freely
    댓글 쓰기
  3. Node Swap, remove old node: 3 단계, 이미지 2개 중 1개 Node Swap, remove old node: 3 단계, 이미지 2개 중 2개
    • first, note if the pin is weight bearing. if so make sure to support the node while you remove the pin (or lock)
    • pull old node out
    댓글 쓰기
  4. Node Swap, replace with new node and measure: 4 단계, 이미지 1개 중 1개
    • after sliding a new node in and replacing the pin or lock, measure the distance from the bottom of the ultrasonic depth sensor cone to the top of the cantilever beam. you may find a spare piece of strut to help with this.
    • you should do this before reattaching the front tapcon or clamp
    댓글 쓰기
  5. Node Swap: 5 단계, 이미지 2개 중 1개 Node Swap: 5 단계, 이미지 2개 중 2개
    • Using a (weighted) tape measure, measure and record the distance from the bottom of the depth sensor node to the bottom of the river.
    • The bottom of the depth sensor node is defined as the bottom of the sensor cone.
    댓글 쓰기
    • if node is drilled into concrete swivel the cantilever back to its full extent and reattach the front tapcon
    • if the node is clamped, reclamp the node at its full extent
    • for a pole-mounted node, you should be able to swap without altering the structure at all
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Travis Dantzer
회원 가입일: 05/06/21
266 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 41
전체 시간: 421
