주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokero SunRay Pro Power Panel Capacitor Replacement
필요한 것
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: 1 단계, 이미지 1개 중 1개
    • Turn over the device so that the back of the device is facing up.
    댓글 쓰기
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: 2 단계, 이미지 3개 중 1개 Nokero SunRay Pro Power Panel Capacitor Replacement: 2 단계, 이미지 3개 중 2개 Nokero SunRay Pro Power Panel Capacitor Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    댓글 쓰기
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: 3 단계, 이미지 2개 중 1개 Nokero SunRay Pro Power Panel Capacitor Replacement: 3 단계, 이미지 2개 중 2개
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    댓글 쓰기
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: 4 단계, 이미지 2개 중 1개 Nokero SunRay Pro Power Panel Capacitor Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    댓글 쓰기
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: 5 단계, 이미지 1개 중 1개
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
    댓글 쓰기
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the capacitor through the circuit board to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Nicholas Orr
회원 가입일: 01/20/15
229 평판
안내서 2개를 작성함
USF Tampa, Team 9-3, Blackwell Winter 2015 USF Tampa, Team 9-3, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 536
