주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia C7 - 00 Touchscreen Replacement
    1. Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 1 단계, 이미지 3개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 1 단계, 이미지 3개 중 2개 Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 1 단계, 이미지 3개 중 3개
      • With a thin tool insert it in the cover at the bottom and pry up to release it
      댓글 쓰기
    2. Nokia  C7 - 00 Touchscreen  Replacement: 2 단계, 이미지 2개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 2 단계, 이미지 2개 중 2개
      • Pry up the two points indicated by the arrows to release the keyboard
      댓글 쓰기
    3. Nokia  C7 - 00 Touchscreen  Replacement: 3 단계, 이미지 2개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 3 단계, 이미지 2개 중 2개
      • Remove battery and battery cover
      댓글 쓰기
    4. Nokia  C7 - 00 Touchscreen  Replacement: 4 단계, 이미지 2개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 4 단계, 이미지 2개 중 2개
      • Unscrew the 2 rear screws
      • Unscrew the 2 front screws
      댓글 쓰기
    5. Nokia  C7 - 00 Touchscreen  Replacement: 5 단계, 이미지 3개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 5 단계, 이미지 3개 중 2개 Nokia  C7 - 00 Touchscreen  Replacement: 5 단계, 이미지 3개 중 3개
      • Gently lift the front glass and slide it slightly in the direction of the arrow so you can free it
      댓글 쓰기
    6. Nokia  C7 - 00 Touchscreen  Replacement: 6 단계, 이미지 3개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 6 단계, 이미지 3개 중 2개 Nokia  C7 - 00 Touchscreen  Replacement: 6 단계, 이미지 3개 중 3개
      • if the display needs to be replaced and then you have no problems if it is broken in the door, proceed with a heat source and a thin tool to be able to break it from underneath
      • If the display is as good as in my case to avoid the risk of breaking it, unscrew the two red arrow screws
      • Gradually unscrew the purple arrow screw so that you do not lose too much on the back of the display to avoid breaking it, at the same time lift it from the keyboard area and gradually unscrew Dino to the complete lifting of the display and its housing doing Leva also laterally on the releases
      댓글 쓰기
    7. Nokia  C7 - 00 Touchscreen  Replacement: 7 단계, 이미지 2개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 7 단계, 이미지 2개 중 2개
      • Lift up display assembly.
      댓글 쓰기
    8. Nokia  C7 - 00 Touchscreen  Replacement: 8 단계, 이미지 3개 중 1개 Nokia  C7 - 00 Touchscreen  Replacement: 8 단계, 이미지 3개 중 2개 Nokia  C7 - 00 Touchscreen  Replacement: 8 단계, 이미지 3개 중 3개
      • Disconnect touch screen connector
      • Disconnect display connector
      댓글 쓰기
결론
To reassemble the device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Smilzo
회원 가입일: 11/09/13
12,359 평판
안내서 39개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 63
전체 시간: 3,061
