주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 2610 Screen Replacement
필요한 것
  1. Nokia 2610 Screen Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 1개 Nokia 2610 Screen Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 2개 Nokia 2610 Screen Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 3개
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    댓글 쓰기
  2. Nokia 2610 Screen Replacement: 2 단계, 이미지 3개 중 1개 Nokia 2610 Screen Replacement: 2 단계, 이미지 3개 중 2개 Nokia 2610 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    댓글 쓰기
  3. Nokia 2610 Screen Replacement: 3 단계, 이미지 3개 중 1개 Nokia 2610 Screen Replacement: 3 단계, 이미지 3개 중 2개 Nokia 2610 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    댓글 쓰기
  4. Nokia 2610 Screen Replacement, Front Pannel: 4 단계, 이미지 2개 중 1개 Nokia 2610 Screen Replacement, Front Pannel: 4 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    댓글 쓰기
  5. Nokia 2610 Screen Replacement: 5 단계, 이미지 2개 중 1개 Nokia 2610 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    댓글 쓰기
  6. Nokia 2610 Screen Replacement, Screen: 6 단계, 이미지 1개 중 1개
    • Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
    댓글 쓰기
  7. Nokia 2610 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the screen away from the phone and circuit board.
    • Warning: The screen is attached to the circuit board by a connector on the circuit board, so lift the screen straight up to avoid damage to the connector.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Wood
회원 가입일: 10/05/10
336 평판
안내서 3개를 작성함
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G52
4 회원들
안내서 24개를 작성함
1가이드 댓글
My Nokia 2610 dates from 2005 (or2006) and its screen was very scratched.
I bought a complete front cover replacement from vmobile.pl who were very efficient.
Andrew Wood’s instructions are crystal clear. The phone is as new now.
Many thanks. Andrew Boxall
Andrew - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 3,678
