주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 6010 screen and speaker replacement
필요한 것
  1. Nokia 6010 screen and speaker replacement, Battery: 1 단계, 이미지 3개 중 1개 Nokia 6010 screen and speaker replacement, Battery: 1 단계, 이미지 3개 중 2개 Nokia 6010 screen and speaker replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    댓글 쓰기
  2. Nokia 6010 screen and speaker replacement: 2 단계, 이미지 2개 중 1개 Nokia 6010 screen and speaker replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery near the bottom and pry up.
    댓글 쓰기
  3. Nokia 6010 screen and speaker replacement, SIM Card: 3 단계, 이미지 1개 중 1개
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    댓글 쓰기
  4. Nokia 6010 screen and speaker replacement, Keypad: 4 단계, 이미지 2개 중 1개 Nokia 6010 screen and speaker replacement, Keypad: 4 단계, 이미지 2개 중 2개
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    댓글 쓰기
  5. Nokia 6010 screen and speaker replacement: 5 단계, 이미지 1개 중 1개
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    댓글 쓰기
  6. Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 6 단계, 이미지 2개 중 1개 Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 6 단계, 이미지 2개 중 2개
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    댓글 쓰기
  7. Nokia 6010 screen and speaker replacement: 7 단계, 이미지 3개 중 1개 Nokia 6010 screen and speaker replacement: 7 단계, 이미지 3개 중 2개 Nokia 6010 screen and speaker replacement: 7 단계, 이미지 3개 중 3개
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicholas Hanne
회원 가입일: 01/20/10
129 평판
안내서 8개를 작성함
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 회원
CPSU-REGAN-W10S14G45
5 회원들
안내서 32개를 작성함
1가이드 댓글
Greatly appreciated !!!
Tobi Hunt - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 47
전체 시간: 4,748
