주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 6086 Screen Replacement
필요한 것
  1. Nokia 6086 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    댓글 쓰기
  2. Nokia 6086 Screen Replacement: 2 단계, 이미지 3개 중 1개 Nokia 6086 Screen Replacement: 2 단계, 이미지 3개 중 2개 Nokia 6086 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    댓글 쓰기
  3. Nokia 6086 Screen Replacement: 3 단계, 이미지 3개 중 1개 Nokia 6086 Screen Replacement: 3 단계, 이미지 3개 중 2개 Nokia 6086 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    댓글 쓰기
  4. Nokia 6086 Screen Replacement, Top Front Cover: 4 단계, 이미지 1개 중 1개
    • Close the phone.
    • Face the front cover forward.
    댓글 쓰기
  5. Nokia 6086 Screen Replacement: 5 단계, 이미지 2개 중 1개 Nokia 6086 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
    댓글 쓰기
  6. Nokia 6086 Screen Replacement: 6 단계, 이미지 3개 중 1개 Nokia 6086 Screen Replacement: 6 단계, 이미지 3개 중 2개 Nokia 6086 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
    댓글 쓰기
  7. Nokia 6086 Screen Replacement, Screen: 7 단계, 이미지 3개 중 1개 Nokia 6086 Screen Replacement, Screen: 7 단계, 이미지 3개 중 2개 Nokia 6086 Screen Replacement, Screen: 7 단계, 이미지 3개 중 3개
    • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
    • Take the T6 driver and remove the screws.
    댓글 쓰기
  8. Nokia 6086 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully lift up the motherboard.
    댓글 쓰기
  9. Nokia 6086 Screen Replacement: 9 단계, 이미지 2개 중 1개 Nokia 6086 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Find the orange slip on the motherboard.
    • Peel back the orange slip to expose the screen.
    댓글 쓰기
  10. Nokia 6086 Screen Replacement: 10 단계, 이미지 3개 중 1개 Nokia 6086 Screen Replacement: 10 단계, 이미지 3개 중 2개 Nokia 6086 Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Place the ipod opening tool under the screen.
    • Remove the damaged screen with the ipod opening tool.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Caitlin Rahm
회원 가입일: 04/15/10
78 평판
안내서 4개를 작성함
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 회원
CPSU-REGAN-S10S26G30
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 32
전체 시간: 3,853
