주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 6102i Inside LCD Display Replacement
필요한 것
  1. Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: 1 단계, 이미지 3개 중 1개 Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: 1 단계, 이미지 3개 중 2개 Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: 1 단계, 이미지 3개 중 3개
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
    댓글 쓰기
  2. Nokia 6102i Inside LCD Display Replacement, Remove Phone Case Screws.: 2 단계, 이미지 2개 중 1개 Nokia 6102i Inside LCD Display Replacement, Remove Phone Case Screws.: 2 단계, 이미지 2개 중 2개
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
    댓글 쓰기
  3. Nokia 6102i Inside LCD Display Replacement, Remove silver and black phone case: 3 단계, 이미지 2개 중 1개 Nokia 6102i Inside LCD Display Replacement, Remove silver and black phone case: 3 단계, 이미지 2개 중 2개
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
    댓글 쓰기
  4. Nokia 6102i Inside LCD Display Replacement, Unplug and Remove Circuit Board: 4 단계, 이미지 2개 중 1개 Nokia 6102i Inside LCD Display Replacement, Unplug and Remove Circuit Board: 4 단계, 이미지 2개 중 2개
    • Pull out the circuit board, which will remove it completely from the case
    댓글 쓰기
  5. Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: 5 단계, 이미지 3개 중 1개 Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: 5 단계, 이미지 3개 중 2개 Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: 5 단계, 이미지 3개 중 3개
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
    댓글 쓰기
  6. Nokia 6102i Inside LCD Display Replacement, Disconnect Interior Display Screen from circuit board.: 6 단계, 이미지 2개 중 1개 Nokia 6102i Inside LCD Display Replacement, Disconnect Interior Display Screen from circuit board.: 6 단계, 이미지 2개 중 2개
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Alex Graebe
회원 가입일: 04/15/10
10 평판
안내서 2개를 작성함
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 회원
CPSU-JOHANN-S10S23G78
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 4,454
