주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 6102i Keyboard Replacement
필요한 것
  1. Nokia 6102i Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nokia 6102i Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nokia 6102i Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
    댓글 쓰기
  2. Nokia 6102i Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
    댓글 쓰기
  3. Nokia 6102i Keyboard Replacement, Logic Board: 3 단계, 이미지 2개 중 1개 Nokia 6102i Keyboard Replacement, Logic Board: 3 단계, 이미지 2개 중 2개
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
    댓글 쓰기
  4. Nokia 6102i Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Nokia 6102i Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
    댓글 쓰기
  5. Nokia 6102i Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Nokia 6102i Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
    댓글 쓰기
  6. Nokia 6102i Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Nokia 6102i Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
    댓글 쓰기
  7. Nokia 6102i Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 1개 Nokia 6102i Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 2개
    • Pop out the keyboard from the frame.
    • Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
    • The picture is showing the three layers: the frame, the keyboard, and the logic board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Jonathan Brophy
회원 가입일: 04/14/10
10 평판
안내서 3개를 작성함
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 회원
CPSU-JOHANN-S10S23G78
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 2,217
