주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 6350-1b Display Screen Replacement
필요한 것
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: 1 단계, 이미지 2개 중 1개 Nokia 6350-1b Display Screen Replacement, Display Screen: 1 단계, 이미지 2개 중 2개
    • Using an iFixit opening tool, separate the plastic frame and the rest of the phone.
    • Move the opening tool along the frame, unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame and set aside.
    • Be careful not to pry too hard; doing so could crack the plastic frame.
    댓글 쓰기
  2. Nokia 6350-1b Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using an opening tool, pry between the screen cover (top left) and the phone frame (top right).
    • To separate, unlock the various groove-like locks on all four sides of the phone.
    • Carefully remove the screen cover (top left) to reveal the logic board (bottom).
    • Keep track of the four small screws. They will be needed to put the phone back together.
    댓글 쓰기
  3. Nokia 6350-1b Display Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the flex cable from the logic board.
    • Disconnect the damaged LCD display screen and remove from the device.
    • Remember to dispose of the damaged LCD display screen responsibly; do not throw away with household trash, as electronic parts are considered household hazardous waste (HHW).
    댓글 쓰기
  4. Nokia 6350-1b Display Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Connect the new LCD display screen to the phone.
    • Reconnect the logic board (bottom right) to the flex cable (gold tab).
    댓글 쓰기
  5. Nokia 6350-1b Display Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using the T-5 screwdriver, screw the four screws back into the phone.
    댓글 쓰기
  6. Nokia 6350-1b Display Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Place the cover back on the device so that it is in the correct position to be reinstalled. Use the opening tool from earlier to direct the cover with precision.
    • Press gently on the cover so that it snaps back into place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Anna
회원 가입일: 04/13/12
25 평판
안내서 2개를 작성함
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G2
2 회원들
안내서 16개를 작성함
1가이드 댓글
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 43
전체 시간: 2,342
