주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 8260 Microphone Replacement
필요한 것
  1. Nokia 8260 Microphone Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the cell phone.
    댓글 쓰기
  2. Nokia 8260 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Press down on the round button on the back cover of the phone.
    댓글 쓰기
  3. Nokia 8260 Microphone Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the back cover down while still pressing the button.
    댓글 쓰기
  4. Nokia 8260 Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  5. Nokia 8260 Microphone Replacement: 5 단계, 이미지 1개 중 1개
    • Press the end of the battery towards the top of the phone.
    댓글 쓰기
  6. Nokia 8260 Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    댓글 쓰기
  7. Nokia 8260 Microphone Replacement, Antenna: 7 단계, 이미지 1개 중 1개
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    댓글 쓰기
  8. Nokia 8260 Microphone Replacement: 8 단계, 이미지 1개 중 1개
    • Pry open the antenna door by pulling down the top of the spudger
    댓글 쓰기
  9. Nokia 8260 Microphone Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the antenna door.
    댓글 쓰기
  10. Nokia 8260 Microphone Replacement: 10 단계, 이미지 1개 중 1개
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    댓글 쓰기
  11. Nokia 8260 Microphone Replacement, Circuit Board: 11 단계, 이미지 1개 중 1개
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    댓글 쓰기
  12. Nokia 8260 Microphone Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the back covering.
    댓글 쓰기
  13. Nokia 8260 Microphone Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the two screws at the top.
    댓글 쓰기
  14. Nokia 8260 Microphone Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    댓글 쓰기
  15. Nokia 8260 Microphone Replacement, Keypad: 15 단계, 이미지 1개 중 1개
    • Remove the plastic border lying on the keypad.
    댓글 쓰기
  16. Nokia 8260 Microphone Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
    댓글 쓰기
  17. Nokia 8260 Microphone Replacement, Microphone: 17 단계, 이미지 1개 중 1개
    • Remove the microphone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Aaron Jen
회원 가입일: 04/11/10
1 평판
안내서 7개를 작성함
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G94
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 28
전체 시간: 1,597
