주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia Asha 201 Screen Replacement
필요한 것
  1. Nokia Asha 201 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Remove back cover of device by pressing firmly and sliding the cover off.
    댓글 쓰기
  2. Nokia Asha 201 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using your finger, lift up on battery to remove from the device.
    댓글 쓰기
  3. Nokia Asha 201 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the two screws from the back case.
    댓글 쓰기
  4. Nokia Asha 201 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Pry off the front case using a iFixit opening tool.
    댓글 쓰기
  5. Nokia Asha 201 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the Keyboard with your hands.
    댓글 쓰기
  6. Nokia Asha 201 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four screws pictured here.
    댓글 쓰기
  7. Nokia Asha 201 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Using the iFixit opening tool, separate the screen from motherboard.
    댓글 쓰기
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
    댓글 쓰기
  8. Nokia Asha 201 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • After plugging in the new screen put back the screen onto the motherboard.
    댓글 쓰기
  9. Nokia Asha 201 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
    댓글 쓰기
  10. Nokia Asha 201 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Using your fingers place the keyboard back like in the picture.
    댓글 쓰기
  11. Nokia Asha 201 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
    댓글 쓰기
  12. Nokia Asha 201 Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
    댓글 쓰기
  13. Nokia Asha 201 Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Using your fingers put back the battery in the back of the phone properly.
    댓글 쓰기
  14. Nokia Asha 201 Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Slide back in the phone cover to the back of the device.
    댓글 쓰기
결론
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Amanda Tresgallos
회원 가입일: 10/10/19
158 평판
안내서 1개를 작성함
USF Tampa, Team S1-G3, Leahy Fall 2019 USF Tampa, Team S1-G3, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G3
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 36
전체 시간: 933
