주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia E61i Microphone Replacement
필요한 것
  1. Nokia E61i Microphone Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nokia E61i Microphone Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
    댓글 쓰기
  2. Nokia E61i Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
    댓글 쓰기
  3. Nokia E61i Microphone Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
    댓글 쓰기
  4. Nokia E61i Microphone Replacement, Front Cover: 4 단계, 이미지 2개 중 1개 Nokia E61i Microphone Replacement, Front Cover: 4 단계, 이미지 2개 중 2개
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
    댓글 쓰기
  5. Nokia E61i Microphone Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the cover by pulling it up and off.
    댓글 쓰기
  6. Nokia E61i Microphone Replacement, Display: 6 단계, 이미지 2개 중 1개 Nokia E61i Microphone Replacement, Display: 6 단계, 이미지 2개 중 2개
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
    댓글 쓰기
  7. Nokia E61i Microphone Replacement: 7 단계, 이미지 2개 중 1개 Nokia E61i Microphone Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
    댓글 쓰기
  8. Nokia E61i Microphone Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 Nokia E61i Microphone Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 Nokia E61i Microphone Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    • Pull the green motherboard from the back casing.
    댓글 쓰기
  9. Nokia E61i Microphone Replacement, Connector Housing: 9 단계, 이미지 1개 중 1개
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
    댓글 쓰기
  10. Nokia E61i Microphone Replacement, Microphone: 10 단계, 이미지 1개 중 1개
    • After the connector housing has been removed, there is nothing else holding the microphone in place. Simply remove it from the housing by pulling up.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Christopher Patton
회원 가입일: 04/07/11
208 평판
안내서 12개를 작성함
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G63
5 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 40
전체 시간: 2,766
