주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia N900 Camera Replacement
필요한 것
  1. Nokia N900 Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
    댓글 쓰기
  2. Nokia N900 Camera Replacement: 2 단계, 이미지 1개 중 1개
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
    댓글 쓰기
  3. Nokia N900 Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery
    댓글 쓰기
  4. Nokia N900 Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
    댓글 쓰기
  5. Nokia N900 Camera Replacement: 5 단계, 이미지 1개 중 1개
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
    댓글 쓰기
  6. Nokia N900 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
    댓글 쓰기
  7. Nokia N900 Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Here are the two main pieces of the camera.
    댓글 쓰기
  8. Nokia N900 Camera Replacement: 8 단계, 이미지 1개 중 1개
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Juan Haro
회원 가입일: 03/13/14
284 평판
안내서 2개를 작성함
New Mexico State, Team 1-4, Easley Spring 2014 New Mexico State, Team 1-4, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G4
4 회원들
안내서 12개를 작성함
1가이드 댓글
Where to find a camera part ?
Thanks
François Soltic - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 21
전체 시간: 1,566
