주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia X Rear-Facing Camera Replacement
필요한 것
  1. Nokia X Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
    댓글 쓰기
  2. Nokia X Rear-Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the battery, simply use your finger to pry the battery out of its slot.
    댓글 쓰기
  3. Nokia X Rear-Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
    댓글 쓰기
  4. Nokia X Rear-Facing Camera Replacement, Display Assembly: 4 단계, 이미지 2개 중 1개 Nokia X Rear-Facing Camera Replacement, Display Assembly: 4 단계, 이미지 2개 중 2개
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
    댓글 쓰기
  5. Nokia X Rear-Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Nokia X Rear-Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
    댓글 쓰기
  6. Nokia X Rear-Facing Camera Replacement: 6 단계, 이미지 1개 중 1개
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
    댓글 쓰기
  7. Nokia X Rear-Facing Camera Replacement, Remove Camera: 7 단계, 이미지 3개 중 1개 Nokia X Rear-Facing Camera Replacement, Remove Camera: 7 단계, 이미지 3개 중 2개 Nokia X Rear-Facing Camera Replacement, Remove Camera: 7 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
    • Remove the camera module by merely picking it up out of its housing slot.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Avery Dorsey
회원 가입일: 01/21/15
1,894 평판
안내서 4개를 작성함
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015 회원
USFT-BROWN-W15S6G1
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 1,300
