주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia XL Dual Sim Battery Replacement
필요한 것
  1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: 1 단계, 이미지 3개 중 1개 Nokia XL Dual Sim Battery Replacement, Replacing the battery: 1 단계, 이미지 3개 중 2개 Nokia XL Dual Sim Battery Replacement, Replacing the battery: 1 단계, 이미지 3개 중 3개
    • Shut off the device completely.
    • Separate the back cover from the device by gently prying the opening out at the loose locations.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
    댓글 쓰기
  2. Nokia XL Dual Sim Battery Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Battery Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Once the back cover is removed, the battery will be in plain sight.
    • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
    댓글 쓰기
  3. Nokia XL Dual Sim Battery Replacement: 3 단계, 이미지 1개 중 1개
    • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
    • Please be aware that your new battery may need to be charged first in order for your device to power back on.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Shadeed Bilal
회원 가입일: 09/25/14
231 평판
안내서 4개를 작성함
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 회원
USFT-BROWN-F14S1G4
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 2,917
