주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia XL Dual Sim Rear Camera Replacement
필요한 것
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: 1 단계, 이미지 1개 중 1개
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    댓글 쓰기
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    댓글 쓰기
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: 3 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: 3 단계, 이미지 2개 중 2개
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    댓글 쓰기
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 2개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    댓글 쓰기
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: 5 단계, 이미지 1개 중 1개
    • Once the device is open, take note of all the components.
    댓글 쓰기
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: 6 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With tweezers, gently release the rear camera motherboard connector.
    댓글 쓰기
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 2개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 3개
    • Gently pull the motherboard connector upward to remove the rear camera component.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Shadeed Bilal
회원 가입일: 09/25/14
231 평판
안내서 4개를 작성함
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 회원
USFT-BROWN-F14S1G4
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 1,126
