주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nook Tablet Midframe Replacement
필요한 것
    1. Nook Tablet Midframe Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Flip the Nook over.
      댓글 쓰기
    2. Nook Tablet Midframe Replacement: 2 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      댓글 쓰기
    3. Nook Tablet Midframe Replacement: 3 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement: 3 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      댓글 쓰기
    4. Nook Tablet Midframe Replacement: 4 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement: 4 단계, 이미지 2개 중 2개
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      댓글 쓰기
    5. Nook Tablet Midframe Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the back panel off the Nook.
      댓글 쓰기
    1. Nook Tablet Midframe Replacement, Screen Bezel: 6 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement, Screen Bezel: 6 단계, 이미지 2개 중 2개
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      댓글 쓰기
    2. Nook Tablet Midframe Replacement: 7 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement: 7 단계, 이미지 2개 중 2개
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      댓글 쓰기
    1. Nook Tablet Midframe Replacement, Disconnect the Battery: 8 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement, Disconnect the Battery: 8 단계, 이미지 2개 중 2개
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      댓글 쓰기
    1. Nook Tablet Midframe Replacement, Midframe: 9 단계, 이미지 1개 중 1개
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      댓글 쓰기
    2. Nook Tablet Midframe Replacement: 10 단계, 이미지 2개 중 1개 Nook Tablet Midframe Replacement: 10 단계, 이미지 2개 중 2개
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Holly Lowe
회원 가입일: 09/26/12
238 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 20
전체 시간: 763
