주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nortel Networks i2004 IP Buttons Replacement
필요한 것
  1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Nortel Networks i2004 IP Buttons Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Nortel Networks i2004 IP Buttons Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
    댓글 쓰기
  2. Nortel Networks i2004 IP Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the seven 8mm Phillips #2 screws.
    댓글 쓰기
  3. Nortel Networks i2004 IP Buttons Replacement: 3 단계, 이미지 2개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    댓글 쓰기
  4. Nortel Networks i2004 IP Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    댓글 쓰기
  5. Nortel Networks i2004 IP Buttons Replacement: 5 단계, 이미지 2개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
    댓글 쓰기
  6. Nortel Networks i2004 IP Buttons Replacement, Circuit Board: 6 단계, 이미지 1개 중 1개
    • Remove the red and white wires from the rubber casing rim.
    댓글 쓰기
  7. Nortel Networks i2004 IP Buttons Replacement: 7 단계, 이미지 2개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
    댓글 쓰기
  8. Nortel Networks i2004 IP Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two 8mm Phillips #2 screws.
    댓글 쓰기
  9. Nortel Networks i2004 IP Buttons Replacement: 9 단계, 이미지 2개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
    댓글 쓰기
  10. Nortel Networks i2004 IP Buttons Replacement: 10 단계, 이미지 3개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 10 단계, 이미지 3개 중 2개 Nortel Networks i2004 IP Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
    댓글 쓰기
  11. Nortel Networks i2004 IP Buttons Replacement: 11 단계, 이미지 2개 중 1개 Nortel Networks i2004 IP Buttons Replacement: 11 단계, 이미지 2개 중 2개
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
    댓글 쓰기
  12. Nortel Networks i2004 IP Buttons Replacement: 12 단계, 이미지 1개 중 1개
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
    댓글 쓰기
  13. Nortel Networks i2004 IP Buttons Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
    댓글 쓰기
  14. Nortel Networks i2004 IP Buttons Replacement, Buttons: 14 단계, 이미지 1개 중 1개
    • Press the broken button from the front of the phone.
    • Remove the broken button through the back.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Wang
회원 가입일: 01/19/12
9 평판
안내서 1개를 작성함
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G35
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 19
전체 시간: 1,317
