주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nostalgia Electrics PCM805 Heating Element
필요한 것
    1. Nostalgia Electrics PCM805 Heating Element, Bowl: 1 단계, 이미지 1개 중 1개
      • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
      • Place the device on a steady table.
      • Lift and remove the rim.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 3개 중 1개 Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 3개 중 2개 Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 3개 중 3개
      • Twist the bowl clockwise until it is free of the groove and lift to remove.
      댓글 쓰기
    3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: 3 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element, Extractor Head: 3 단계, 이미지 2개 중 2개
      • Firmly grip the extractor head and slowly lift vertically to remove from the device.
      댓글 쓰기
    1. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 4 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 4 단계, 이미지 2개 중 2개
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Heating Element: 5 단계, 이미지 1개 중 1개
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      댓글 쓰기
    1. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 6 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 6 단계, 이미지 2개 중 2개
      • Locate the tie strap holding the wires and cut with a pair of scissors.
      • Use care not to snip the wires.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 3개 중 1개 Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 3개 중 2개 Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 3개 중 3개
      • Make note of the wiring arrangement of each bundle before this step.
      • Using wire cutters, cut each wire as close to the wire connector as possible.
      • Cut the wires in both bundles.
      • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
      댓글 쓰기
    1. Nostalgia Electrics PCM805 Heating Element, Heating Element: 8 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element, Heating Element: 8 단계, 이미지 2개 중 2개
      • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
      • Remove the metal housing.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Heating Element: 9 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element: 9 단계, 이미지 2개 중 2개
      • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
      댓글 쓰기
    3. Nostalgia Electrics PCM805 Heating Element: 10 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Heating Element: 10 단계, 이미지 2개 중 2개
      • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nicholas Fazio
회원 가입일: 01/13/15
194 평판
안내서 1개를 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 16개를 작성함
2가이드 댓글
Where can I buy a replacement heating element?
Eric P. Rose - 답글 공유
For the heating element, the grate popped off. What silicone is used to keep the parts together? Same for the springs inside the white tubes.
Jenilee Brown - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 52
전체 시간: 6,254
