주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nostalgia Electrics PCM805 Power Switch Replacement
필요한 것
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: 1 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: 1 단계, 이미지 2개 중 2개
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Power Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      댓글 쓰기
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: 3 단계, 이미지 1개 중 1개
      • Locate the switch/wire assembly inside the device.
      댓글 쓰기
    2. Nostalgia Electrics PCM805 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Pull back the insulation sleeves to expose the connector heads.
      댓글 쓰기
    3. Nostalgia Electrics PCM805 Power Switch Replacement: 5 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Power Switch Replacement: 5 단계, 이미지 2개 중 2개
      • Note the color of each wire and the order you remove them.
      • Using a pair of pliers, firmly grip the base of the wire.
      • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
      • Pull the wire straight out of the switch.
      • Repeat this step for each wire.
      댓글 쓰기
    4. Nostalgia Electrics PCM805 Power Switch Replacement: 6 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Power Switch Replacement: 6 단계, 이미지 2개 중 2개
      • Using pliers, pinch tabs at the top and bottom of switch.
      • While pinching the tabs, push the switch until the tabs are on the outside of the device.
      댓글 쓰기
    5. Nostalgia Electrics PCM805 Power Switch Replacement: 7 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Power Switch Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the switch from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Carlton
회원 가입일: 01/13/15
672 평판
안내서 5개를 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 16개를 작성함
1가이드 댓글
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 2,323
