주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nostalgia GCM200 Power Button Replacement
필요한 것
    1. Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 2개 중 1개 Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 2개 중 2개
      • Remove the two 1.3 mm Phillips #2 screws.
      • Remove the S6 spanner screw.
      • Carefully place these three screws somewhere safe to use later in reassembly.
      댓글 쓰기
    2. Nostalgia GCM200 Power Button Replacement: 2 단계, 이미지 1개 중 1개
      • Split the device in half to expose the internal parts of the device.
      • Again, there are two more Phillips screws to remove.
      댓글 쓰기
    3. Nostalgia GCM200 Power Button Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two screws from both sides of the heating coil.
      댓글 쓰기
    1. Nostalgia GCM200 Power Button Replacement, Power Button: 4 단계, 이미지 1개 중 1개
      • Split the device into 2 parts to change the power button.
      • Power button hold the other parts, so be careful.
      댓글 쓰기
    2. Nostalgia GCM200 Power Button Replacement: 5 단계, 이미지 1개 중 1개
      • Remove (flexible) plastic sleeves from the inside end of the power cable.
      • You might want to use force, pull out while shaking it.
      • Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
      댓글 쓰기
    3. Nostalgia GCM200 Power Button Replacement: 6 단계, 이미지 1개 중 1개
      • Depress the little tab inside the top portion of the device to remove the On/Off switch.
      댓글 쓰기
    4. Nostalgia GCM200 Power Button Replacement: 7 단계, 이미지 1개 중 1개
      • Replace the power button, and put the plastic sleeves in the original position.
      • Great, you just finished replacing power button
      댓글 쓰기
    5. Nostalgia GCM200 Power Button Replacement: 8 단계, 이미지 1개 중 1개
      • To reassemble your device, follow these instructions in reverse order.
      댓글 쓰기
결론
This guide will help you to replace the power button
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Xingdi Zhou
회원 가입일: 06/27/17
466 평판
안내서 3개를 작성함
UW Tacoma, Team S1-G4, Liner Summer 2017 UW Tacoma, Team S1-G4, Liner Summer 2017 회원
UWT-LINER-SU17S1G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 425
