주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
NuVision TM800A510L Battery Replacement
필요한 것
    1. NuVision TM800A510L Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 NuVision TM800A510L Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Use a Heat Gun to loosen the adhesive under the backing of the device.
      • Use prying tools to lift up the back of the device to get underneath.
      • I recommend concentrating on one side of the device at a time and making sure the device is 'almost too hot to touch' before you begin using the prying tools.
      • You can use either metal or plastic prying tools. Keep in mind, though, that metal ones may scratch the device.
      댓글 쓰기
    2. NuVision TM800A510L Battery Replacement: 2 단계, 이미지 2개 중 1개 NuVision TM800A510L Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Unlock all of the ribbons that cross or interfere with the battery.
      • Remove the unlocked ribbons if you can- this will make it easier to work with the battery later.
      댓글 쓰기
    3. NuVision TM800A510L Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Use plastic prying tools to peel up the battery. Metal prying tools may puncture the battery and cause more damage. If you MUST use metal prying tools, go slow.
      • This process may take some time since the battery is held down with adhesive.
      • It is not really recommended to use the Heat Gun on the battery. However, the heat will loosen the adhesive. Therefore, if you decide to use a Heat Gun, apply the heat to the battery from underneath the device (heat the screen).
      댓글 쓰기
    4. NuVision TM800A510L Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Desolder battery and wires from Motherboard HERE!
      • Once the wires are free, so is the battery. You should be able to replace the battery and its wires in full (as a package deal).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Kelsey Riggs
회원 가입일: 01/25/17
486 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 41
전체 시간: 1,417
