주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Display Assembly Replacement
필요한 것
  1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 1개 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 2개 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 3개
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    댓글 쓰기
  2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 1개 Nvidia Shield Display Assembly Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 2개
    • The green grill is not screwed in so it can be pulled right out.
    댓글 쓰기
  3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 1개 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 2개 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 3개
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
    댓글 쓰기
  4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: 4 단계, 이미지 1개 중 1개
    • Pull the battery apparatus out once all cables are removed.
    댓글 쓰기
  5. Nvidia Shield Display Assembly Replacement, Removing Fan: 5 단계, 이미지 3개 중 1개 Nvidia Shield Display Assembly Replacement, Removing Fan: 5 단계, 이미지 3개 중 2개 Nvidia Shield Display Assembly Replacement, Removing Fan: 5 단계, 이미지 3개 중 3개
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
    댓글 쓰기
  6. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: 6 단계, 이미지 1개 중 1개
    • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
    • Once removed, the display should be able to be detached.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Noel Fletcher
회원 가입일: 09/22/14
116 평판
안내서 1개를 작성함
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개를 작성함
1가이드 댓글
Where can o get a replacement screen
jorge valenzuela - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 64
전체 시간: 7,201
