주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV Fan/Heat Sink Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
    댓글 쓰기
  2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: 2 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: 2 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: 2 단계, 이미지 3개 중 3개
    • Remove the five screws with a T6 Torx screwdriver.
    • Two of the screws are located directly on top of the fan/heat sink. The other three screws are located on a small triangle plate on the left side of the fan/heat sink.
    댓글 쓰기
  3. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: 3 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: 3 단계, 이미지 2개 중 2개
    • Once the screws are removed, gently detach the multi-colored wired connection from the motherboard.
    댓글 쓰기
  4. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the fan/heat sink out of the Nvidia Shield.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jimmy Chen
회원 가입일: 01/23/20
753 평판
안내서 3개를 작성함
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 회원
CPSU-WHITE-W20S18G2
4 회원들
안내서 14개를 작성함
7가이드 댓글
Hello can you tell me where to buy the fan and the plastic case opener?
Sajid Idrees - 답글 공유
From iFixit is generally the best for plastic spudgers/openers.
as for the fan apparently the Fan Model Number is BAZA0508R5U and there's plenty available on ebay and amazon.
Nic Ganglen - 답글 공유
My version had screws in the back which I had to remove, and then I could simply slide it away from the ports in the back to open it. The inside was completely different as well, but it's a pretty simple device.
John Doe - 답글 공유
This is the 500GB 2015 version they're showing.
Joseph Oliveira - 답글 공유
I have the Shield TV Pro Model: P2897 (2019 version)-> The latest model, even though it's 7 years old as of 2/1/25.
The pictures shown here looks nothing like the model I have.
You would think that even though these instructions provide detailed information on how to replace the abnormally noisy Fan that they would include information on what MODEL they're using here, unbelievable.
Proflex.Fitness - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 47
지난 30일: 283
전체 시간: 17,486
