주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV I/O Board Replacement
필요한 것
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
    댓글 쓰기
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 2 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 2 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 2 단계, 이미지 3개 중 3개
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
    댓글 쓰기
  3. Nvidia Shield Pro Android TV I/O Board Replacement: 3 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 3 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV I/O Board Replacement: 3 단계, 이미지 3개 중 3개
    • Detach the pack of wires by pulling it away from the socket.
    댓글 쓰기
  4. Nvidia Shield Pro Android TV I/O Board Replacement: 4 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 4 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV I/O Board Replacement: 4 단계, 이미지 3개 중 3개
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
    댓글 쓰기
  5. Nvidia Shield Pro Android TV I/O Board Replacement: 5 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
    댓글 쓰기
  6. Nvidia Shield Pro Android TV I/O Board Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the hard drive out of the device.
    댓글 쓰기
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 7 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 7 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 7 단계, 이미지 3개 중 3개
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
    댓글 쓰기
  8. Nvidia Shield Pro Android TV I/O Board Replacement: 8 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 8 단계, 이미지 2개 중 2개
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
    댓글 쓰기
  9. Nvidia Shield Pro Android TV I/O Board Replacement: 9 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the three T6 Torx screws from the I/O board.
    댓글 쓰기
  10. Nvidia Shield Pro Android TV I/O Board Replacement: 10 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV I/O Board Replacement: 10 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV I/O Board Replacement: 10 단계, 이미지 3개 중 3개
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
    댓글 쓰기
  11. Nvidia Shield Pro Android TV I/O Board Replacement: 11 단계, 이미지 1개 중 1개
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jimmy Chen
회원 가입일: 01/23/20
753 평판
안내서 3개를 작성함
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 회원
CPSU-WHITE-W20S18G2
4 회원들
안내서 14개를 작성함
2가이드 댓글
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - 답글 공유
Aniyone managed to get a source for this part, The IO board
Yoda Mann - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 31
지난 30일: 159
전체 시간: 7,410
