주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield TV 1st Generation Controller Battery Replacement
필요한 것
    1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: 1 단계, 이미지 2개 중 1개 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: 1 단계, 이미지 2개 중 2개
      • Remove the indicated six screws using the T6 Torx screwdriver.
      댓글 쓰기
    2. Nvidia Shield TV 1st Generation Controller Battery Replacement: 2 단계, 이미지 2개 중 1개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to pry the face of the controller away from the body.
      • Make sure the controller is face down during this step as the buttons can easily fall out.
      댓글 쓰기
    3. Nvidia Shield TV 1st Generation Controller Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the indicated ribbon wires from the face of the controller.
      댓글 쓰기
    4. Nvidia Shield TV 1st Generation Controller Battery Replacement: 4 단계, 이미지 2개 중 1개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      $3.99
      • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
      • Lift the vibration motor out of the front case.
      • Repeat for the other side.
      • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
      댓글 쓰기
    5. Nvidia Shield TV 1st Generation Controller Battery Replacement: 5 단계, 이미지 3개 중 1개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 5 단계, 이미지 3개 중 2개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
      • Lift the logic board away from the front case.
      댓글 쓰기
    6. Nvidia Shield TV 1st Generation Controller Battery Replacement: 6 단계, 이미지 3개 중 1개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 6 단계, 이미지 3개 중 2개 Nvidia Shield TV 1st Generation Controller Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
      • Remove the panel from the front case.
      • Lift the battery from the front case to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joshua Neally
회원 가입일: 09/25/17
581 평판
안내서 4개를 작성함
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G6
3 회원들
안내서 14개를 작성함
8가이드 댓글
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - 답글 공유
LC18650 Remote Control accu
djcornelissen - 답글 공유
Are battery packs available for the 2017 controller?
Andrew - 답글 공유
Simply reconnecting the battery fixed my issues
Charles Keisler - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 62
전체 시간: 21,683
