주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Tablet Speaker Replacement
필요한 것
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Nvidia Shield Tablet Speaker Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • First, remove the stylus from your tablet.
    댓글 쓰기
  2. Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 3개 중 1개 Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 3개 중 2개 Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
    댓글 쓰기
  3. Nvidia Shield Tablet Speaker Replacement: 3 단계, 이미지 2개 중 1개 Nvidia Shield Tablet Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
    댓글 쓰기
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
    댓글 쓰기
  5. Nvidia Shield Tablet Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
    댓글 쓰기
  6. Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 3개 중 1개 Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 3개 중 2개 Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
    댓글 쓰기
  7. Nvidia Shield Tablet Speaker Replacement: 7 단계, 이미지 2개 중 1개 Nvidia Shield Tablet Speaker Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $7.95
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Molly Bauer
회원 가입일: 08/27/15
1,478 평판
안내서 6개를 작성함
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G2
3 회원들
안내서 11개를 작성함
1가이드 댓글
This didn't work
Riley Schork - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 57
전체 시간: 3,163
