주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oculus Quest 2 Controller Disassembly
필요한 것
    1. Oculus Quest 2 Controller Disassembly, Remove Screws From Inside Battery Compartment: 1 단계, 이미지 2개 중 1개 Oculus Quest 2 Controller Disassembly, Remove Screws From Inside Battery Compartment: 1 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Start by opening the battery compartment and removing the batteries, using your fingers or something else to gently pull them out.
      • Peel off the three stickers that are hiding screws using your fingernails or something pointy, such as a pair of tweezers.
      • The stickers cover three of the screws. They are not shown in this image.
      • Unscrew the three T5 Torx screws behind the stickers using a small Torx screwdriver.
      • Remove the fourth screw located inside the hole near the top of the battery compartment using the same Torx screwdriver.
      댓글 쓰기
    2. Oculus Quest 2 Controller Disassembly, Pry The Faceplate Off: 2 단계, 이미지 1개 중 1개
      • Gently pry the faceplate off using a spudger or flathead screwdriver.
      • The plate is secured with adhesive, so it may be a little difficult the first time you remove it. You don't need to worry since it is also held in place using plastic posts.
      댓글 쓰기
    3. Oculus Quest 2 Controller Disassembly, Remove Screws From Under The Faceplate: 3 단계, 이미지 1개 중 1개
      • Remove the five Torx T5 screws.
      • Remove the longer, black T5 screw.
      • Remove the two smaller T4 screws.
      • These screws may be difficult to remove. Use constant, downward force with your driver to prevent stripping.
      • Remove the single long silver T5 screw.
      댓글 쓰기
    4. Oculus Quest 2 Controller Disassembly, Remove Outer Plastic Shell: 4 단계, 이미지 1개 중 1개
      • Use a spudger or screwdriver to press the plastic notch until it releases.
      • Starting from the side without the notch, gently remove the casing using your hands by moving it away from the center of the console.
      댓글 쓰기
    5. Oculus Quest 2 Controller Disassembly, Pry Controller Apart: 5 단계, 이미지 3개 중 1개 Oculus Quest 2 Controller Disassembly, Pry Controller Apart: 5 단계, 이미지 3개 중 2개 Oculus Quest 2 Controller Disassembly, Pry Controller Apart: 5 단계, 이미지 3개 중 3개
      • There is a plastic pin that is inserted into a hole, to separate the parts you need to be a bit careful in the steps below.
      • Using your hands, move the left half of the handle slightly (0.5cm) away from the controller.
      • While holding the left side as described above, push the right side towards the body of the controller.
      • Now you are able to slide the right part to the right and remove it.
      • The pin is located here.
      댓글 쓰기
    6. Oculus Quest 2 Controller Disassembly, Disconnect The Ribbon from Main Circuit Board: 6 단계, 이미지 3개 중 1개 Oculus Quest 2 Controller Disassembly, Disconnect The Ribbon from Main Circuit Board: 6 단계, 이미지 3개 중 2개 Oculus Quest 2 Controller Disassembly, Disconnect The Ribbon from Main Circuit Board: 6 단계, 이미지 3개 중 3개
      • Disconnect the ribbon. There is a latch (possibly black - opposite from the ribbon side of the connector) you flip up on the main circuit board (blue arrow). This is easy to take apart but a pain to put back together. Make sure you have needle-nose pliers or tweezers for this when you put it back together.
      • The main circuit board is not the battery circuit board you first come to. As seen in the 2nd and 3rd images.
      • Blue arrow points to ribbon connector on main circuit board. White arrows on 2nd & 3rd images point to ribbon and connector latch on battery circuit board.
      • The connector can be damaged if you are not careful.
      댓글 쓰기
    7. Oculus Quest 2 Controller Disassembly, Remove Screws From Circuit Board And Disconnect Joystick: 7 단계, 이미지 1개 중 1개
      • Now, you need to remove the 4 screws holding the circuit board to the controller.
      • The joystick has a small ribbon (blue ribbon) as well, but it is easy to connect and disconnect. Flip the latch up to disconnect the joystick ribbon.
      • You are NOT going to remove it completely, just lift it high enough to remove the joystick.
      댓글 쓰기
    8. Oculus Quest 2 Controller Disassembly, Remove Joystick: 8 단계, 이미지 1개 중 1개
      • Lift up the circuit board and pull the joystick free. The X button and the Oculus button may fall out. Not a big deal, just make sure they are put back in the correct position before sealing everything up.
      댓글 쓰기
    9. Oculus Quest 2 Controller Disassembly, Remove Rubber Cap: 9 단계, 이미지 1개 중 1개
      • Pull the rubber cap off of the joystick.
      댓글 쓰기
    10. Oculus Quest 2 Controller Disassembly, Open Joystick Housing: 10 단계, 이미지 1개 중 1개
      • The housing is held together by the tabs on the bottom plate. Bend them back to pop it off. Be careful doing this, there are a lot of little pieces and a spring that can go flying.
      댓글 쓰기
    11. Oculus Quest 2 Controller Disassembly, Joystick Parts Bottom Row: 11 단계, 이미지 1개 중 1개
      • Here are all of the pieces inside the joystick on the bottom row.
      • 1 - The sensor that causes drift when dirty
      • 2 - The bottom part of the joystick that the stick fits into. This is what moves the sensor left/right.
      • 3 - This piece sits on top of #2. This is what moves the sensor up/down
      • 4 - The stick. This fits through the hole in #3 and fits inside #2.
      • 5 - These two pieces are what make contact with the sensor and they are moved around by #2 and #3
      • MISSING FROM PICTURE - There is a little black plastic piece that is in the shape of an arch that locks #2 into place in the housing.
      댓글 쓰기
    12. Oculus Quest 2 Controller Disassembly, Joystick Parts Top Row: 12 단계, 이미지 1개 중 1개
      • Here are all of the pieces inside the joystick on the top row.
      • 6 - Metal housing
      • 7 - Spring for pressing down on the joystick
      • 8 - Metal ring to keep the joystick in place and to create contract with the spring (#7)
      • 9 - Plastic housing
      댓글 쓰기
    13. Oculus Quest 2 Controller Disassembly, Clean Sensor And Contacts: 13 단계, 이미지 1개 중 1개
      • Now that you have it taken apart, use contact cleaner to clean both pieces in the red box on the right and clean the sensor in the red box on the left. Cleaning the sensor is the most important. After spraying with contact cleaner, I use a small paint brush to clean it.
      • The 3 black sections (blue arrows) are what recognize up/down/left/right. If there is anything on those, it causes drift. The more you use the controller, the more the black material breaks down and leaves residue behind. Also, the more you use it, the more sweat/dust/dirt find their way into the housing.
      • If you use the controller long enough, eventually this will breakdown and can't be fixed. This is a problem with all controllers, not just Oculus.
      댓글 쓰기
    14. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 14 단계, 이미지 1개 중 1개
      • Place #3 into the plastic housing
      댓글 쓰기
    15. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 15 단계, 이미지 1개 중 1개
      • Put the stick through the opening and attach #2 to the bottom of the stick like this. Both #2 and #3 can only sit in the plastic housing a certain way. If it doesn't move correctly, this is probably the problem.
      댓글 쓰기
    16. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 16 단계, 이미지 1개 중 1개
      • Slightly push the stick up so that you can place both #5s in the groove. #2 and #3 sit on top of #5. At this point you should be able to see how the joystick makes #5 move.
      댓글 쓰기
    17. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 17 단계, 이미지 1개 중 1개
      • Place the metal ring on.
      댓글 쓰기
    18. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 18 단계, 이미지 1개 중 1개
      • Place the spring on and the tiny little black piece. That tiny little black piece (blue arrow) locks #2 in place.
      댓글 쓰기
    19. Oculus Quest 2 Controller Disassembly, Reassemble Joystick Housing: 19 단계, 이미지 1개 중 1개
      • Put the sensor on the metal housing. It can only fit one way.
      • Now, sandwich the housing together without letting anything slip.
      • Bend the metal tabs back into place so that it is secured.
      댓글 쓰기
    20. Oculus Quest 2 Controller Disassembly, Conclusion: 20 단계, 이미지 1개 중 1개
      • Reverse the instructions to put it back together. Be careful with the ribbon I mentioned in Step 6.
      • Some of the pieces require a little finesse to reassemble, especially the piece that goes around the trigger.
      • Make sure that you didn't disconnect any of the ribbons. The last time I did this, I accidentally loosened one of the ribbons under the trigger (blue arrow) and eventually it disconnected.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 82명이 해당 안내서를 완성하였습니다.
작성자
16다른 기여자 명과 함께
matty_mac_21
회원 가입일: 02/17/22
1,932 평판
안내서 1개를 작성함
48가이드 댓글
i wanna know how the controller worke. infared or bluetooth, or even area positioning system bull $@$*, please help actually sent from my quest 2
Soren Nordgren - 답글 공유
The controller uses infared to connect to the quest 2.
Lucas C - 답글 공유
That's BS. It uses Bluetooth 5.0 LE. The Quest 2 has no way to send or recieve IR
Blus cream - 답글 공유
Both replies are half right. The controllers use BT to connect to the headset for functionality, but positional tracking is done via infrared in the halos. The 4 cameras on the front of the headset are infrared cameras.
Justin P - 답글 공유
Yeah, a basic inspection of the controller says it does not operate by infrared. Infrared is an optic device, and the controller has no optics. I'll stick with Lucas on this one.
Tj Casteel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 89
지난 7일: 590
지난 30일: 2,596
전체 시간: 215,899
