주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oculus Rift DK1 Control Box Buttons Replacement
필요한 것
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 1 단계, 이미지 3개 중 1개 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 1 단계, 이미지 3개 중 2개 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 1 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
      • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
      댓글 쓰기
    2. Oculus Rift DK1 Control Box Buttons Replacement: 2 단계, 이미지 3개 중 1개 Oculus Rift DK1 Control Box Buttons Replacement: 2 단계, 이미지 3개 중 2개 Oculus Rift DK1 Control Box Buttons Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
      • You can now remove the bottom lid of the control box. It should come apart easily.
      댓글 쓰기
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 3 단계, 이미지 3개 중 1개 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 3 단계, 이미지 3개 중 2개 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 3 단계, 이미지 3개 중 3개
      • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
      • When the DVI connector has cleared the casing, lift the motherboard.
      • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
      • When reassembling the device, ensure that all of the wires are clear of the buttons.
      댓글 쓰기
    2. Oculus Rift DK1 Control Box Buttons Replacement: 4 단계, 이미지 3개 중 1개 Oculus Rift DK1 Control Box Buttons Replacement: 4 단계, 이미지 3개 중 2개 Oculus Rift DK1 Control Box Buttons Replacement: 4 단계, 이미지 3개 중 3개
      • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
      • Do so for both of the wires attached to the motherboard.
      • Now fully separate the motherboard from the control box casing.
      댓글 쓰기
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: 5 단계, 이미지 1개 중 1개
      • You now have the motherboard separated from the control box.
      • Identify the buttons that are not working.
      댓글 쓰기
    2. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: 6 단계, 이미지 1개 중 1개
      • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
      • Be careful! Soldering iron is hot.
      댓글 쓰기
    3. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: 7 단계, 이미지 2개 중 1개 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
      • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Ross De Vito
회원 가입일: 01/13/15
246 평판
안내서 2개를 작성함
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 회원
CPSU-FORTE-W15S70G5
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 10
지난 30일: 27
전체 시간: 989
