주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oculus Rift Development Kit 2 Headset Motherboard Replacement
필요한 것
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 3개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 3개 중 2개 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 3개 중 3개
      • Remove front cover plate.
      • Unplug the USB and HDMI cables from the Oculus Rift DK2.
      댓글 쓰기
    2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
      댓글 쓰기
    3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • With the screws removed, gently pull the headband frame apart from the headset.
      댓글 쓰기
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 4 단계, 이미지 2개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 4 단계, 이미지 2개 중 2개
      • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
      댓글 쓰기
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
      댓글 쓰기
    2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
      • Read the next step before removing the faceplate!
      댓글 쓰기
    3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
      • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
      댓글 쓰기
    4. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
      • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
      • The headset should now be two separate pieces.
      댓글 쓰기
    5. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
      댓글 쓰기
    6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
      댓글 쓰기
    7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 3개 중 3개
      • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Adam
회원 가입일: 01/20/15
661 평판
안내서 4개를 작성함
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015 회원
CPSU-MANESS-W15S18G5
4 회원들
안내서 42개를 작성함
1가이드 댓글
hi.
you know where possible buy the new motherboard?
Szatmari Attila - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 40
전체 시간: 2,988
