주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oculus Rift Tracker V2 Board Replacement
필요한 것
    1. Oculus Rift Tracker V2 Board Replacement, Lens: 1 단계, 이미지 2개 중 1개 Oculus Rift Tracker V2 Board Replacement, Lens: 1 단계, 이미지 2개 중 2개
      • To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
      댓글 쓰기
    1. Oculus Rift Tracker V2 Board Replacement, Display: 2 단계, 이미지 2개 중 1개 Oculus Rift Tracker V2 Board Replacement, Display: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
      댓글 쓰기
    2. Oculus Rift Tracker V2 Board Replacement: 3 단계, 이미지 3개 중 1개 Oculus Rift Tracker V2 Board Replacement: 3 단계, 이미지 3개 중 2개 Oculus Rift Tracker V2 Board Replacement: 3 단계, 이미지 3개 중 3개
      • Carefully lift the headstrap from the display. The two parts should separate easily enough with some force.
      • Once the headstrap assembly and display box are separated, the headstrap assembly can be set aside. You will be working with the display box for the rest of this guide!
      댓글 쓰기
    3. Oculus Rift Tracker V2 Board Replacement: 4 단계, 이미지 2개 중 1개 Oculus Rift Tracker V2 Board Replacement: 4 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, pry open the display box to reveal the LCD (Liquid Crystal Display) screen. Run the plastic opening tool around all four edges. Prying open the box may take a good amount of force.
      댓글 쓰기
    4. Oculus Rift Tracker V2 Board Replacement: 5 단계, 이미지 3개 중 1개 Oculus Rift Tracker V2 Board Replacement: 5 단계, 이미지 3개 중 2개 Oculus Rift Tracker V2 Board Replacement: 5 단계, 이미지 3개 중 3개
      • Run the plastic opening tool along the bottom edge under the LCD screen to separate the adhesive holding the LCD to the display box.
      • Lift the screen up to reveal the wires and circuit board.
      • Ensure that all wires are in the right place upon reassembly.
      댓글 쓰기
    5. Oculus Rift Tracker V2 Board Replacement: 6 단계, 이미지 2개 중 1개 Oculus Rift Tracker V2 Board Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the wires from the circuit board on the LCD display using your fingernail or a plastic opening tool. This may take some pushing and pulling of the plastic piece.
      • Don't pull on the wires! Be sure to only pry the plastic part.
      • You can now completely separate the LCD screen from the rest of the device!
      댓글 쓰기
    1. Oculus Rift Tracker V2 Board Replacement, Oculus Tracker V2 Board: 7 단계, 이미지 1개 중 1개
      • Remove wires from the Tracker V2 Board using your fingernail or a plastic opening tool.
      댓글 쓰기
    2. Oculus Rift Tracker V2 Board Replacement: 8 단계, 이미지 3개 중 1개 Oculus Rift Tracker V2 Board Replacement: 8 단계, 이미지 3개 중 2개 Oculus Rift Tracker V2 Board Replacement: 8 단계, 이미지 3개 중 3개
      • On the front cover of the Oculus Headset, locate the Tracker V2 Board.
      • Using the Plastic Opening Tool, pry the board from the adhesive. You will need to lift from both sides of the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jake Finelt
회원 가입일: 01/15/15
146 평판
안내서 1개를 작성함
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 회원
CPSU-FORTE-W15S70G5
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 1,567
