주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Olympus D590 Retainer Clip Replacement
필요한 것
    1. Olympus D590 Retainer Clip Replacement, Face Plate: 1 단계, 이미지 1개 중 1개
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Olympus D590 Retainer Clip Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      댓글 쓰기
    3. Olympus D590 Retainer Clip Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      댓글 쓰기
    4. Olympus D590 Retainer Clip Replacement: 4 단계, 이미지 1개 중 1개
      • Using tweezers, lift the rubber plate to expose the ports.
      댓글 쓰기
    5. Olympus D590 Retainer Clip Replacement: 5 단계, 이미지 1개 중 1개
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      댓글 쓰기
    6. Olympus D590 Retainer Clip Replacement: 6 단계, 이미지 1개 중 1개
      • Use a spudger to pry the faceplate away from the rest of the camera.
      댓글 쓰기
    7. Olympus D590 Retainer Clip Replacement: 7 단계, 이미지 1개 중 1개
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      댓글 쓰기
    1. Olympus D590 Retainer Clip Replacement, Retainer Clip: 8 단계, 이미지 1개 중 1개
      • Orient the camera as shown, with the bottom facing up.
      • Open the retainer clip, by using your finger to push down and slide to the left.
      • The clip should pop open.
      댓글 쓰기
    2. Olympus D590 Retainer Clip Replacement: 9 단계, 이미지 1개 중 1개
      • Hold the retainer clip down (without re-latching it).
      • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
      댓글 쓰기
    3. Olympus D590 Retainer Clip Replacement: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to continue to remove the pin.
      댓글 쓰기
    4. Olympus D590 Retainer Clip Replacement: 11 단계, 이미지 1개 중 1개
      • When it feels loose, pull the pin all the way out with your fingers.
      댓글 쓰기
    5. Olympus D590 Retainer Clip Replacement: 12 단계, 이미지 1개 중 1개
      • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Katie
회원 가입일: 04/15/10
31 평판
안내서 3개를 작성함
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 회원
CPSU-REGAN-S10S28G23
4 회원들
안내서 49개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 25
전체 시간: 2,574
