주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Olympus Digital Camera TG-3 Shutter Button Replacement
필요한 것
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: 1 단계, 이미지 1개 중 1개
      • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
      댓글 쓰기
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: 2 단계, 이미지 1개 중 1개
      • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
      댓글 쓰기
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: 3 단계, 이미지 1개 중 1개
      • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
      댓글 쓰기
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: 4 단계, 이미지 1개 중 1개
      • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
      댓글 쓰기
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: 5 단계, 이미지 1개 중 1개
      • Now you should be able to remove the front case easily using your hand.
      댓글 쓰기
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: 6 단계, 이미지 1개 중 1개
      • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
      댓글 쓰기
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: 7 단계, 이미지 1개 중 1개
      • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
      댓글 쓰기
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: 8 단계, 이미지 1개 중 1개
      • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
      댓글 쓰기
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: 9 단계, 이미지 1개 중 1개
      • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
      댓글 쓰기
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: 10 단계, 이미지 1개 중 1개
      • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
      댓글 쓰기
    6. Olympus Digital Camera TG-3 Shutter Button  Replacement: 11 단계, 이미지 1개 중 1개
      • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
      댓글 쓰기
    7. Olympus Digital Camera TG-3 Shutter Button  Replacement: 12 단계, 이미지 1개 중 1개
      • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
      댓글 쓰기
    8. Olympus Digital Camera TG-3 Shutter Button  Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the back case using your hand.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Natalia Morales
회원 가입일: 10/11/16
675 평판
안내서 5개를 작성함
USF Tampa, Team 1-6, Leahy Fall 2016 USF Tampa, Team 1-6, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G6
3 회원들
안내서 10개를 작성함
2가이드 댓글
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - 답글 공유
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 64
전체 시간: 4,395
