주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Olympus FE-210 Lens Assembly Replacement
필요한 것
  1. Olympus FE-210 Lens Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
    댓글 쓰기
  2. Olympus FE-210 Lens Assembly Replacement: 2 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
    댓글 쓰기
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: 3 단계, 이미지 3개 중 1개 Olympus FE-210 Lens Assembly Replacement, Front Casing: 3 단계, 이미지 3개 중 2개 Olympus FE-210 Lens Assembly Replacement, Front Casing: 3 단계, 이미지 3개 중 3개
    • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
    댓글 쓰기
  4. Olympus FE-210 Lens Assembly Replacement: 4 단계, 이미지 3개 중 1개 Olympus FE-210 Lens Assembly Replacement: 4 단계, 이미지 3개 중 2개 Olympus FE-210 Lens Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
    • These three places are located:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
    댓글 쓰기
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: 5 단계, 이미지 1개 중 1개
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
    댓글 쓰기
  6. Olympus FE-210 Lens Assembly Replacement: 6 단계, 이미지 3개 중 1개 Olympus FE-210 Lens Assembly Replacement: 6 단계, 이미지 3개 중 2개 Olympus FE-210 Lens Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
    댓글 쓰기
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
    댓글 쓰기
  8. Olympus FE-210 Lens Assembly Replacement: 8 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the seven 2.7 mm using a #00 screwdriver.
    댓글 쓰기
  9. Olympus FE-210 Lens Assembly Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
    댓글 쓰기
  10. Olympus FE-210 Lens Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
    댓글 쓰기
  11. Olympus FE-210 Lens Assembly Replacement: 11 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
    댓글 쓰기
  12. Olympus FE-210 Lens Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the motherboard from the camera casing.
    댓글 쓰기
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: 13 단계, 이미지 1개 중 1개
    • Remove the three 3.6 mm screws using a #00 screwdriver.
    댓글 쓰기
  14. Olympus FE-210 Lens Assembly Replacement: 14 단계, 이미지 2개 중 1개 Olympus FE-210 Lens Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Matt
회원 가입일: 01/25/11
826 평판
안내서 6개를 작성함
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 회원
CPSU-REGAN-W11S4G36
3 회원들
안내서 14개를 작성함
1가이드 댓글
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 59
전체 시간: 7,269
