주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Olympus Stylus 410 Slider Replacement
필요한 것
    1. Olympus Stylus 410 Slider Replacement, Slider: 1 단계, 이미지 1개 중 1개
      • Locate the 2 screws on the bottom of the slider.
      • Remove both screws with a #00 Phillips screwdriver.
      댓글 쓰기
    2. Olympus Stylus 410 Slider Replacement: 2 단계, 이미지 1개 중 1개
      • Gently pull on the bottom of the slider until it comes off the lower track.
      • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
      댓글 쓰기
    3. Olympus Stylus 410 Slider Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the slider up until it comes off the upper track.
      댓글 쓰기
    4. Olympus Stylus 410 Slider Replacement: 4 단계, 이미지 1개 중 1개
      • The slider should now be free from the body of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jared Ruekberg
회원 가입일: 04/15/10
33 평판
안내서 2개를 작성함
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 회원
CPSU-MANESS-S10S6G13
5 회원들
안내서 18개를 작성함
2가이드 댓글
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - 답글 공유
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 66
전체 시간: 4,653
