주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Onda V701 Battery Replacement
필요한 것
    1. Onda V701 Battery Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Onda V701 Battery Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Onda V701 Battery Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      댓글 쓰기
    2. Onda V701 Battery Replacement: 2 단계, 이미지 3개 중 1개 Onda V701 Battery Replacement: 2 단계, 이미지 3개 중 2개 Onda V701 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      댓글 쓰기
    3. Onda V701 Battery Replacement: 3 단계, 이미지 2개 중 1개 Onda V701 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      댓글 쓰기
    4. Onda V701 Battery Replacement: 4 단계, 이미지 2개 중 1개 Onda V701 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      댓글 쓰기
    5. Onda V701 Battery Replacement: 5 단계, 이미지 3개 중 1개 Onda V701 Battery Replacement: 5 단계, 이미지 3개 중 2개 Onda V701 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      댓글 쓰기
    1. Onda V701 Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
      • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
      댓글 쓰기
    2. Onda V701 Battery Replacement: 7 단계, 이미지 3개 중 1개 Onda V701 Battery Replacement: 7 단계, 이미지 3개 중 2개 Onda V701 Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Carefully pry the battery away from the back panel using the nylon or metal spudger.
      • Gently remove the battery from the back panel.
      • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bradley Huber
회원 가입일: 03/11/15
366 평판
안내서 3개를 작성함
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015 회원
UCCS-PANKO-S15S4G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 1,260
