주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
One Education Infinity Touchpad Replacement
필요한 것
  1. One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
    댓글 쓰기
  2. One Education Infinity Touchpad Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
    댓글 쓰기
  3. One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
    댓글 쓰기
  4. One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
    댓글 쓰기
  5. One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
    댓글 쓰기
  6. One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
    댓글 쓰기
  7. One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 3개
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
    댓글 쓰기
  8. One Education Infinity Touchpad Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
    댓글 쓰기
  9. One Education Infinity Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
    댓글 쓰기
  10. One Education Infinity Touchpad Replacement: 10 단계, 이미지 1개 중 1개
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
    댓글 쓰기
  11. One Education Infinity Touchpad Replacement: 11 단계, 이미지 1개 중 1개
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
    댓글 쓰기
  12. One Education Infinity Touchpad Replacement: 12 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 12 단계, 이미지 2개 중 2개
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
    댓글 쓰기
  13. One Education Infinity Touchpad Replacement: 13 단계, 이미지 1개 중 1개
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
    댓글 쓰기
  14. One Education Infinity Touchpad Replacement: 14 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 14 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
    댓글 쓰기
  15. One Education Infinity Touchpad Replacement, Touchpad: 15 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
    댓글 쓰기
  16. One Education Infinity Touchpad Replacement: 16 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 16 단계, 이미지 2개 중 2개
    • Peel back the black tape.
    • Using your fingers, carefully lift the metal plate out of the internal panel.
    댓글 쓰기
  17. One Education Infinity Touchpad Replacement: 17 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the two 2mm silver screws.
    댓글 쓰기
  18. One Education Infinity Touchpad Replacement: 18 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 18 단계, 이미지 2개 중 2개
    • Using your fingers, carefully lift the touch-pad out of the internal panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Jason Childers
회원 가입일: 10/10/19
109 평판
안내서 1개를 작성함
Cal Poly, Team S11-G4, Regan Fall 2019 Cal Poly, Team S11-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S11G4
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 530
