주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
One Education Infinity:One Camera Assembly Replacement
필요한 것
  1. One Education Infinity:One Camera Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 One Education Infinity:One Camera Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
    댓글 쓰기
  2. One Education Infinity:One Camera Assembly Replacement: 2 단계, 이미지 3개 중 1개 One Education Infinity:One Camera Assembly Replacement: 2 단계, 이미지 3개 중 2개 One Education Infinity:One Camera Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
    댓글 쓰기
  3. One Education Infinity:One Camera Assembly Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity:One Camera Assembly Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity:One Camera Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
    댓글 쓰기
  4. One Education Infinity:One Camera Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
    댓글 쓰기
  5. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 5 단계, 이미지 3개 중 1개 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 5 단계, 이미지 3개 중 2개 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 5 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
    댓글 쓰기
  6. One Education Infinity:One Camera Assembly Replacement: 6 단계, 이미지 2개 중 1개 One Education Infinity:One Camera Assembly Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the black cushion surrounding the camera lens.
    댓글 쓰기
  7. One Education Infinity:One Camera Assembly Replacement: 7 단계, 이미지 2개 중 1개 One Education Infinity:One Camera Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,159 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 536
