주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 3 Battery Replacement
필요한 것
    1. OnePlus 3 Battery Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 3개
      • Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
      • Press firmly to eject the SIM card tray.
      • During reinstallation, make sure that the SIM card tray is properly oriented. It fits in only one direction.
      댓글 쓰기
    1. OnePlus 3 Battery Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
      • Remove the two 2.6 mm T2 screws from the bottom edge of the phone.
      댓글 쓰기
    2. OnePlus 3 Battery Replacement: 3 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 3 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
      • The following three steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
      • There are two different seams between the screen and the body of the phone:
      • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
      • Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
      • There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
      댓글 쓰기
    3. OnePlus 3 Battery Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
      • Place a suction cup near the bottom edge of the display.
      • Pull on the suction cup with strong steady force.
      • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
      • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
      • Do not use metal tools, as they will most likely crack the screen.
      댓글 쓰기
    4. OnePlus 3 Battery Replacement: 5 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 5 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
      • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
      댓글 쓰기
    5. OnePlus 3 Battery Replacement: 6 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Continue sliding the opening tool along the long edge, releasing the clips along the way.
      • The last clip in the top-left corner near the alert switch is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
      댓글 쓰기
    6. OnePlus 3 Battery Replacement: 7 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 7 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 7 단계, 이미지 3개 중 3개
      • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
      • Lift the screen up and remove it.
      • During reassembly, pause here to test your phone's functionality before securing the back cover.
      • To reinstall the back cover:
      • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
      • Squeeze along the long edges of the phone to snap the remaining clips into place.
      댓글 쓰기
    1. OnePlus 3 Battery Replacement, OnePlus 3 Battery Disconnect: 8 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement, OnePlus 3 Battery Disconnect: 8 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
      • Bend the connector away from the socket to prevent accidental contact.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      댓글 쓰기
    1. OnePlus 3 Battery Replacement, OnePlus 3 Interconnect Cable Disconnect: 9 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement, OnePlus 3 Interconnect Cable Disconnect: 9 단계, 이미지 2개 중 2개
      • Remove the 3 mm Phillips screw securing the cable bracket.
      • Remove the cable bracket.
      댓글 쓰기
    2. OnePlus 3 Battery Replacement: 10 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 10 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 10 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
      • Repeat the process to disconnect the daughterboard flex cable from the motherboard.
      댓글 쓰기
    1. OnePlus 3 Battery Replacement, Battery: 11 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement, Battery: 11 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the daughterboard, which is located below the battery.
      댓글 쓰기
    2. OnePlus 3 Battery Replacement: 12 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the interconnect flex cable.
      • Carefully bend the still-attached daughterboard flex cable away from the battery.
      • During reassembly, make sure that the Main labeled connector connects to the motherboard. The Sub connector will fit the motherboard socket but it will cause your phone to malfunction.
      댓글 쓰기
    3. OnePlus 3 Battery Replacement: 13 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement: 13 단계, 이미지 2개 중 2개
      • Use the opening tool to push any adhesive tape holding the battery to the edge of the plastic frame. There should be at least one on each battery side.
      • Be careful not to puncture the battery pack with the tool.
      댓글 쓰기
    4. OnePlus 3 Battery Replacement: 14 단계, 이미지 1개 중 1개
      • Peel the clear pull tab up from the battery.
      댓글 쓰기
    5. OnePlus 3 Battery Replacement: 15 단계, 이미지 3개 중 1개 OnePlus 3 Battery Replacement: 15 단계, 이미지 3개 중 2개 OnePlus 3 Battery Replacement: 15 단계, 이미지 3개 중 3개
      • Brace the phone frame against the table.
      • Using a strong, steady force, pull the clear pull tab upwards until the battery loosens from its recess.
      • If you are having a hard time, apply some high concentration (over 90%) isopropyl alcohol along the battery seam to help weaken the adhesive.
      • Swing the battery completely out of its recess and pull off of any remaining adhesive.
      댓글 쓰기
    6. OnePlus 3 Battery Replacement: 16 단계, 이미지 2개 중 1개 OnePlus 3 Battery Replacement: 16 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Tesa 61395 Tape
      $8.95
      • Remove the battery and any remaining adhesive residue on the frame.
      • Do not reuse the battery after it has been removed. Reusing a battery that is bent or otherwise stressed is a potential safety hazard.
      • If your replacement battery did not come with a pull tab, you can transfer the old tab to the new battery to help with subsequent replacements.
      • While installing a new battery, temporarily connect the battery to the phone to ensure proper battery alignment.
      • To install a new battery onto an existing frame, remove some adhesive strips from a pre-cut adhesive card, or cut some strips from a roll of Tesa tape, and stick them in the highlighted area.
      • If you are installing a battery onto a new screen and digitizer assembly, be sure to peel off the orange adhesive liner to expose the battery adhesive for the new battery.
      댓글 쓰기
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 58명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,889 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 48,411개를 작성함
14가이드 댓글
This is a great run down! I am rather scared with step 3 so I think I am going to have someone else repair it for me.
subwayfox - 답글 공유
Is this tutorial and the repair kit also applicable for the OnePlus 3T model? Thanks in advance for helping!
Useless User - 답글 공유
The tutorial for the 3T model would be similar, but not completely identical to this guide. Since the battery capacity is different between the 3 and 3T, the repair kit would not be applicable. However, the tools are most likely the same.
Arthur Shi - 답글 공유
Thanks for your response Arthur! Is it planned to offer a battery kit also for the OnePlus 3T? I’d definitely appreciate it since I can’t find any trustworthy OnePlus 3T batteries so far. Best regards!
Unfortunately, I don’t think we are releasing a 3T battery kit anytime soon.
Arthur Shi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 31
지난 30일: 139
전체 시간: 46,514
